TPS Sensor
Old Feb 18, 2009 | 09:02 PM
thirdgen4me's Avatar
TPS Sensor
My car idles high and spits out a TPS code, O2 code and Map code sometimes. Is there any way to test the TPS instead of buying a new one for $40?
Old Feb 19, 2009 | 11:53 AM
Tightenloop's Avatar
Car: Camaro LT
Transmission: 700r-4
Re: TPS Sensor
You can test TPS by voltmeter. (basic test)
1. Turn ignition on.
2. connect digital voltmeter black wire to ground. and red wire to the center wire of tps (TPS should be still nconnected to wire from ecu.)
3. Read the voltage (it should be ~0.5 V)
if you get higher voltage adjust TPS posision to 0.5 V.
4. Slowly open the trottle.
while opening voltage should increase up to 4.5-5.0V at WOT
If Your voltage doesnt change You have worn TPS.
If you do not get voltage on TPS at all disconnect tps and measure voltage between two side pins. on a wire connector.
You should read ~5V (or -5.0V if wrong polarity) if You dont read 5V make sure ignition is on. If ignition is on and no voltage check wires to ecu etc.
If voltage between a central pin and ground is constant while opening and is ~5.0v check TPS ground wire. if groung is OK than You have bad TPS.
Old Feb 19, 2009 | 09:01 PM
Re: TPS Sensor
Ok well I have access to a nice Snap-On scan tool...Can I watch the TPS on there? Also are the TPS on a camaro adjustable?
Old Feb 20, 2009 | 06:18 AM
Car: Camaro LT
Re: TPS Sensor
TPS is adjustable on any car.
With any scan -tool you can see only what ECU sees. For example if You have worn TPS ground wire ECU will cause TPS error code (because voltage on TPS central wire will not change during trottle moving) while TPS itself is good.
I really suggest you to perform test above.
Old Feb 20, 2009 | 07:36 PM
Re: TPS Sensor
Well I had 7 codes on my car and saw that the TPS was putting out 0.02V when I had the scanner hooked up. So I bought a TPS for $26 and boom perfect!!
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
bbsr72
Apr 2, 2016 09:12 AM
Fred SS
Oct 12, 2015 11:27 AM
BWilcox
Sep 20, 2015 12:19 PM
