Very exciting... I think we figured it out!
Old Feb 25, 2009 | 03:03 PM
Aarons92Maro's Avatar
Car: 1992 Camaro RS & 1994 Mazda 626
Engine: 305 TBI V8 / 2.0 4-cyl.
Transmission: 700R4 / I have no idea
Axle/Gears: Stock 2.73 / I don't know
I've posted at least five different threads about my timing issues after switching the 305 I bought back to a 305 TBI. As I have mentioned, it was fast as a carb'd car, but just ran really bad, also due to a failing fuel pump. We swapped the car back to a TBI, did the whole swap, but I think the distributor was left in it from when it was carb'd. The car will not start unless the timing cable is unplugged, it'll sputter for five seconds and die. The car, after the timing is replugged in, is dead slow. 0-60 in over 14 seconds! Could this be the dizzy?I posted this question on another section but people were ignoring it, and I'm hoping to get an answer here before I leave.Thanks!!!
Old Feb 25, 2009 | 03:25 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Very exciting... I think we figured it out!
did you ever shoot a timing gun at that thing? unplug the dizzy, connect the trigger lead to #1 and aim the gun down at the balancer it, you should be at 0* or maybe a bit advanced if you like.
where are you leaving to?
this pic will help you with the timing tab:
Attached Thumbnails Very exciting... I think we figured it out!-timingtab.jpg
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
