Weiand X-celerator intake manifold issues
Old Feb 16, 2009 | 02:13 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Everything looks good on it, except the coolant hose next to the distributer on the stock intake manifold. I assume that hose is for the heater. Does the 7547 X-celerator have one in a different location that im missing? Or is there anyway around this?
Thanks.
Old Feb 17, 2009 | 07:35 AM
Damon's Avatar
Re: Weiand X-celerator intake manifold issues
Yes, that hose is for your heater core.
Lots of intakes don't have provisions for a rear-mounted heater hose. It goes up front on the coolant crossover next to the thermostat housing. A longer hose to the heater core is required as well, obviously.
Old Feb 17, 2009 | 09:02 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
hmm i just had a look at these, it says rpm range is 2k-6500. looks like your gonna lose some more power down low. do you already have one or were you just looking at it as an option?
btw i think with the performers you'd also have to use the coolant crossover up front.
Old Feb 17, 2009 | 12:40 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Alright, so it just goes up front then? Well then I guess ill be ordering one
I dont have the intake yet, its a single plane so it doesent have as much low end power as a dual plane, but with the cam/head combo I have almost all my power is above 4,000rpm so a single plane would fit good.
Old Feb 17, 2009 | 09:34 PM
Tas's Avatar
Tas
I bought a 7547 weiand intake years ago. I just got my car back. Hopefully i can find the intake at my dads work somewhere to put it on.
Old Feb 25, 2009 | 05:27 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Im a little confused where the brake booster goes on this intake?
Never mind, i just have to use a T fittings.
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
Jake_92RS
Aug 11, 2015 10:39 AM
