spark plug installation
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: ???? want 4.10's
so i am going to put plugs in the car tomorrow and i'm thinking i would ask the experts whats the easiest way to replace them. besides paying the shop.
thanks
thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: spark plug installation
A little patience and anti seize go a long way. You will want to have access to undernieth the car and a spark plug wrench makes things much easier. One can be had on ebay for $5 to $10. Other than that it is pretty straight forward.
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I concur, you definitely want some extension sockets along with the sparkplug socket...both can be had at WalMart for $5 to $10...or any autoparts store... Make sure the engine is cold so you don't burn your fingers on the block and heads...
Car: 89 Camaro RS
Engine: 5.0 TBI
it actually wasn't as hard as it looked. only took me about 30 minutes. did all but the front two under the car.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
