overheating unless interior fan is on
Old Mar 7, 2009 | 09:22 AM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
unless i have the air or heat on the temp starts creepin up what can be causin this?
Old Mar 7, 2009 | 10:12 AM
vorticaldavid's Avatar
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
Re: overheating unless interior fan is on
your fan switch could have gone out, i had that problem with my car
Old Mar 7, 2009 | 10:17 AM
8urv8's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6 w/.425" cam (Int. & Exh.)
Axle/Gears: Stock
yeah, the fan is prolly not cutting on by itself. when you turn the air on it's turning the fan on too. when you turn it off, so does the fan. check the fan temp. switch.
Old Mar 7, 2009 | 12:35 PM
Car: 91 rs
Engine: 305tbi
where is the fan switch located?
Old Mar 7, 2009 | 04:48 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
fan switch is located on the passenger cylinder head between the last 2 cylinders.
Old Apr 19, 2009 | 10:21 PM
Car: 91 rs
Engine: 305tbi
how can i tell if it is bad short of letting it heat up to 240* to see if it turns on? i know ive seen switches claiming it turns the fans on at 180* do these work? any reccomendations, part numbers greatly appreciated
Old Apr 20, 2009 | 01:28 AM
Jason89RS's Avatar
You can disconnect the connection from the switch and then short out the connection. If the fan comes on when you short the connection then the switch is bad. I'm running a 180* thermostat and a fan switch from an 87 Buick Grand National which goes on at 220 and off at 204. Napa part number ECHFS113.
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
