92 9c1 injectors
Old Mar 15, 2009 | 08:56 AM
got_tork's Avatar
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
92 9c1 injectors
I have a 92 RMW w/L05. I have just completed the ultimate TBI mod and was wondering if I run the 92 9c1 injectors (65lbs) over the stock 60's do I need the ECM from the 9c1? Any help would be appreciated
Old Mar 15, 2009 | 01:01 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: 92 9c1 injectors
That's about an 8% increase in fuel (assuming no pressure change).
I doubt you'd ever notice the difference. Might want to free up the air path, or cool it down - then you might notice a bit of change.
Run 'em for a bit, then check the color on your plugs. That'll tell you.
Old Mar 15, 2009 | 08:09 PM
Jono4820's Avatar
Car: 1991 RS
Engine: 350 TBI
Axle/Gears: 3.08 lt. slip
I swapped the 350, esc module, injectors, and ECM from a 92 9C1. All worked very well. I first tried swapping just the chips but had to swap ecms to make car(s) run properly. I would swap ecm if you have it unless you are going to custom program a chip in the one you already have.
92-Formula
Dec 12, 2015 10:34 PM
BLK87Z
Sep 18, 2015 11:29 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
