ignition problems?
Old Apr 3, 2009 | 03:33 AM
95chevyTBI's Avatar
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
ignition problems?
i had installed a new engine(from heads down). my problem is that spark plugs 1,3,5,7 have normal wear. 2,4,6,8 have black spots like if the engine is running rich. i tried to find a vacuum leak but found none. can someone suggest a solution?
oh, and my mpg is 11.
Old Apr 3, 2009 | 07:27 AM
zipfast's Avatar
Car: 94 9c1 Caprice
Engine: LT1 (3-fity)
Transmission: 4L60E reBUILT
Axle/Gears: 3:08 POSI (out)
Re: ignition problems?
Sounds like you have an injector hanging open / dripping.
Take the air cleaner off and turn the key on to get pressure,
look to see if one leaks.
Old Apr 3, 2009 | 03:32 PM
95chevyTBI's Avatar
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
i checked how you told me but the weird thing is that when i put the key forward the fuel pressure guage does not show any pressure. it shows pressure until i start the engine. i cant figure out why it does that.
Old Apr 4, 2009 | 12:23 AM
fiveoformula's Avatar
Car: 1988 Formula Firebird
Engine: 5.3 LM4
Transmission: 4L65E
Axle/Gears: 3.42 True-Trac
Did you "T" the line or did you "dead head" the pump?
Old Apr 4, 2009 | 02:14 AM
95chevyTBI's Avatar
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
i used one of these.
http://cgi.ebay.com/ebaymotors/GM-TB...mZ250400291439
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
