Holley 670 TBI Review
Old Apr 3, 2009 | 05:05 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
To anyone out there running the 670 Holley unit:
I'm looking to get more out of my TBI. It currently runs 13.6's in the 1/4 mile with a stock 350 TBI unit sitting on top of the motor. (No ultimate TBI mods) Estimated 330-340hp. What will i realistically see from swapping my stock 350 TBI unit to the 670cfm Holley unit?
Also, what do the stock 350 TBI units flow in terms of cfm?
Thanks.
Old Apr 4, 2009 | 02:50 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: Holley 670 TBI Review
I am interested inhearing your complete setup. as far as heads, cam, compression, chip (or tuning). that's a pretty good time
Old Apr 4, 2009 | 03:25 PM
91GmCVoRtEc's Avatar
Car: 90 GMC C1500
Engine: 350 Vortec
Transmission: Dying 700-R4
Axle/Gears: Stock 3:08
Well, with proper tuning for the added cfm, the 670 will make for a HUGE topend power gain. I just got mine about 2 weeks ago, got rid of the stock and it made an crazy deference on a 90 gmc truck that is very out of tune. It pulls hard enough that i'm scared that i'm going to break something like the rearend or something. by the way, if you are like me, get the 89 model of holley tbi because my truck is a 90, but has the flat style tps connector. the 90-95 670 tbi's have the round style like the lt1. Plus the 89 tbi is 439$ and the 90-95 is 504$ Dont ask why i dont know, but the 89 one came with everything i needed to mount it.
Old Apr 5, 2009 | 01:21 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Vortec heads
GMPP Aluminum intake
55lb injectors
Comp cam .425/.440 with a 112 lsa
Not too sure on compression guessing around the 9-10 range (cant remember..)
Tune by TBI Chips
B&M 2300 converter
B&M Shift kit
3.42 posi 4th gen rear
Edelbrock shortys to a flowmaster
Old Apr 5, 2009 | 02:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Originally Posted by irishhockey34
Vortec heads
55lb injectors
Tune by TBI Chips
B&M 2300 converter
B&M Shift kit
Why in the world would you run 55# 305 injectors on that engine? I hope you are running the high pressure regulator and atleast a TPI pump. Hole'd pistons are never fun.
Old Apr 5, 2009 | 08:58 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
If i am correct, the stock injectors in a 305 are 40lb. 55lb's came in the 350's.
Old Apr 5, 2009 | 09:27 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
GM injector application and size
4.3 = 46#
5.0 = 55#
5.7 = 61# on non police/vortec models
Old Apr 5, 2009 | 09:36 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
I had the holley TB on my 305 in my T/A. It ran decent but ran very rich as i never tuned it. Only drove the car for a short time before i parked it for winter with the holley on it but it pulled very good in the high end but low end seemed the same as stock. I have it for sale now if your looking to buy one. Let me know.
Old Apr 5, 2009 | 09:55 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
4.3 = 46#
5.0 = 55#
5.0 = 40#
5.7 = 55#
5.7 = 61# for police interceptor
Reference: https://www.thirdgen.org/forums/diy-...ctor-info.html
Old Apr 5, 2009 | 10:10 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
5.0 = 40#
5.7 = 55#
WRONG, WRONG, WRONG....That list was from a time when we barely even knew the injectors had a color code to them.
5.0 = 55#
5.7 = 61#
5.7 = 65# for the Square Body Caprice 9C1
5.7 = 68# for the Round Body Caprice
Old Apr 5, 2009 | 10:12 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
So be it, the car still runs like a top. Stock fuel pump and reg.
Old Apr 5, 2009 | 10:16 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
and it is very likely running lean.. I have seen a ZZ4 swapped into a 1995 truck, running a Hypertech chip, that the guy thought was running like a top (and it DID at part-throttle) run so lean that it melted the pistons out of it. In my pre-wideband days, I took the tops off of some pistons on a TBI build as well..
This is the correct chart..
http://www.turbocity.com/default.php?cPath=16_30
61# running at 12 psi is enough fuel for only 240ish flywheel HP. Your engine should be making ATLEAST 300 flywheel horsepower. See the problem. Just trying to save you alot of grief.
EDIT- FWIW I know all too well myself. I melted 3 pistons on a long highway pull, near WOT in my Van. The piston looks like that because it melted the aluminum away and deposited it all over it and the chamber.
Old Apr 5, 2009 | 10:19 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
what injector size/fuel pressure would you recommend for my setup?
Old Apr 5, 2009 | 10:42 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
If you are making 330 HP you need 90#/hr worth of fuel per injector. Which means you need the ability to tune for the increased fue delivery at lower rpms and part-throttle.
Old Apr 6, 2009 | 11:08 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
and what do you mean by that. increased fp and a new tune? or variable regulator?
Old Apr 6, 2009 | 11:33 AM
Ronny's Avatar
VAFPR allows better control of idle quality. When you significantly increase the fuel pressure to adequately fuel WOT with large injectors the ECU attempts to reduce the pulse width at idle causing issues. Some will say car has better all around drivability as well with VAFPR. Unfortunately it requires swapping ECU to one that will support a vacuum based reference to BPC.
Old Apr 6, 2009 | 11:48 AM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Say the fuel pressure is bumped up from ~12psi to ~18 psi. Will this increase cause idling issues? Or are you talking significant fuel pressure increases?
Old Apr 6, 2009 | 12:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
It takes 28.5 psi of fuel pressure to get 61#/hr injectors to flow 90#/hr.
At .45 BSFC and 85% duty cycle that is good for 341 HP.
RBob.
Old Apr 6, 2009 | 01:07 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
RBob,
Will I still be pressing my luck if I do the following:
50mm Bored TBI
50mm bored GMPP manifold
afpr
255 fuel pump
Thanks.
Old Apr 6, 2009 | 03:04 PM
87cmroiroc305ho's Avatar
Car: 1987 chevy camaro iroc-z28 305 h.o.
Engine: 305 high output
i am very interested in getting my tbi running at least 50 more horse than stock, without losing too much mpg's cuz its a d.d. how would i adjust the regulator, where is it? ive been in and out of third gens, had 4 of them, and dont know where they are. lol. some simple tuning to add a couple horse would be nice
Old Apr 6, 2009 | 03:21 PM
Ronny's Avatar
fuel pressure reg is on bottom of injector pod behind injectors....
http://z28boy.cz28.com/main.htm see TBI tech-TBI info
Old Apr 6, 2009 | 03:27 PM
Ronny's Avatar
Old Apr 6, 2009 | 04:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
RBob,
50mm Bored TBI
afpr
255 fuel pump
Thanks.
Not if you also increase the fuel pressure to 30 psi. But it will be a bear to get tuned on a stock ECM.
Note that with the 255 LPH fuel pump you won't be able to set the fuel pressure lower then say 18 to 22 psi. I don't know the exact pressure value, hence the range. What happens is that the TBI unit & FPR become a restriction to the fuel flow. Which back pressures the system.
RBob.
Old Apr 6, 2009 | 05:58 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Thanks for all of the info guys. You're really helping me out here. RBob again, by bumping up the fuel pressure and using a 50mm throttle body, what gains can you see coming out of this?
Old Apr 6, 2009 | 06:06 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Just thought I would pass this one back to you. This should be the 30 PSI GM Marine VAFPR regulator.. If not its the normal 18 psi one. But based on the time frame and the application, it should be the 30 PSI unit.
http://cgi.ebay.com/ebaymotors/Boat-...1%7C240%3A1318
Old Apr 6, 2009 | 08:25 PM
how would i tune it to make higher psi at the injectors
Old Apr 6, 2009 | 08:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Well you would need to be able to program the chip to dial back the fuel at part throttle.
Making the system run at higher pressure is easy. Just need the GM high pressure regulator, TPI pump in the tank, and replace the little piece of fuel hose between the pump and sending unit.
Old Apr 7, 2009 | 06:31 PM
duderjay's Avatar
Car: 88 iroc z28
RBob.
Hey Rbob would a pro using a dyno be able to tune a stock ecm with engine mods to have around 350 fwhp?
Great thread guys
Old Apr 7, 2009 | 06:48 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Great thread guys
There are really too many variables for me to answer this. A lot has to do with the displacement and the cam used to get the 350 fwhp. The wider the LDA/LSA on the cam the easier it will be to tune. The larger the displacement, the milder the build will be. This also makes it easier to tune.
The biggest issue with the '8746 & '7747 ECMs is that the VE tables don't have enough resolution. This can lead to surging issues that can not be tuned out.
Although most of the time a dyno tune only consists of WOT. This isn't hard to tune in. It is the driveability and the ability to idle that are the issue.
RBob.
Old Apr 7, 2009 | 08:13 PM
duderjay's Avatar
Car: 88 iroc z28
RBob.
ok then how bout 131 block .010 over, heads vortec stock, lt4 hotcam 9.7 to one compression and if I have clearance 1.6 ratio rockers, manifold theres a few in this forum i have an eye on, also tbi would be bored to 2 inch and cop injectors and of course press reg and tpi pump.
in an 88 iroc with the stock ecm
Old Apr 7, 2009 | 08:30 PM
denice25's Avatar
looks interesting...
Old Apr 8, 2009 | 09:36 AM
Ronny's Avatar
I dont think many of us on these boards have used a "pro" to tune our engines. Some have paid for a chip. tbichip.com. I would think the ecomonics of it might be prohibitive. Correct me if I am wrong but a speed density aka SD is a bit more difficult to tune. That adds to more time on the dyno and time is $$$ a we know. Certainly some of us have done WOT runs to see what we have but not expressidly to do a tune. MAF cars I believe are considerably less difficult. If fact there is an advertiser in Chev Hi Perf that says their system tunes itself! Now if you move to Corvette Forun aka CF you have a different economics and some of those cars are higher value so the time on dyno and cost is proportionately less. Besides DIY is a rewarding experience.
Old Apr 8, 2009 | 11:35 PM
duderjay's Avatar
Car: 88 iroc z28
Thanks for that I am trying to weigh the pros and cons of tuning myself or having some one else do it. As for some one else doing the $$$ is not an issue for me. But like you have just said if i do the tuning myself it would be a good experience. I may back off on some of the hp expections to have an easier time to tune if i do it myself. Also in consideration is time I dont want to be tuning for a year man I travel for a living and with 3 kids.....
Thanks for the input guys
Old Apr 13, 2009 | 09:38 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
I purchased one of these Holley units for my 88 iroc, and I have it on a Edelbrock Rpm intake manifold pre 87. I have a 1" carb spacer also. I can see a very big difference in the injectors and the amount of fuel they spit out. Now I see people talking about these units. So is there anything else I should know about this unit? Or do any other mods to the car for her? I see everyone talking about AFPR's.... Should I be putting one on the car? Are they recommended with this unit? Also is the stock fuel pump good enough?? Let me know what you guys think I should do. Thanks.
Old Apr 14, 2009 | 10:24 AM
Ronny's Avatar
Stock fuel pump is only good to 13 psi and if aged maybe wont hold 13 at WOT. The Aero VAFPR or GM for that matter allows one to run high fuel pressure yet maintain idle control. W/O VAFPR the high fuel pressure causes ECU to cut fuel to maintain A/F and pulse width gets too low(<1.00) and causes havoc with idle quality(surging). It is said the VAFPR also allows better throttle response off idle as well. Vehicle just runs better ion and off throttle. The ECU you run needs to be able to change BPC as VAC changes. Not sure if the later GM ECU's (TPI) will do that? I believe they use a VAFPR so prob so. EBL does. dynamicefi.com.
Old Apr 14, 2009 | 11:10 AM
Car: 88 IROC-z
Engine: LO3 V8 305
Well I will be getting my ECU flashed, or a TBI chip put in by TBIchips.com
Now what is a VAFPR?? is that a Vacuum AFPR??? If so how come We need a Vacuum AFPR? and not a Normal one??
Now I just put in a stock fuel pump becuase the old one was shot. I guess I shall be going in there to replace the fuel sending unit, because my gas gauge does not work. So When I go in there I guess Ill go get a 255 walbro???
Well thanx for the info/.
Old Apr 14, 2009 | 11:23 AM
Ronny's Avatar
Be warned Wal 255 may be too much. Wal 190 is available. VAFPR reduces the flow under VAC. I idle 63 VAC or 37 MAP. WOT my FP is 23.5 lbs. VAFPR pulls it down to 13.5-14.0 lbs FP. VAFPR is variable fuel .....
Now I believe it also works reverse under boost. IOW 0 VAC-100 MAP is WOT so 125-150 MAP under boost it increases FP assuming FP pumpwill allow. Someone correct me on that if WRONG.
Old Apr 14, 2009 | 11:34 AM
Car: 88 IROC-z
Engine: LO3 V8 305
Soooo I guess I will be looking for a VAFPR?? For my car and a nice Wal 190 FP??
Now what else will I have to do? Any other setups or modds needed? SInce I have done some mods to my car?
Also does any1 know where to get lines to replace the stock fuel lines and those hard lines?? Id like to run sum Braided hose if possible.
Old Apr 14, 2009 | 02:18 PM
Ronny's Avatar
I used a TPI pump. Not sure if Wal 190 is superior. Cost?
I used synthetic pust fit EFI hose and filttings from Aeroquip. I believe Earls and summit sells similar. Real easy to use. heat up end in hot water and push it on barbed fitting. Slick. Reusable and easy to cut with utility knife to size.
Old Apr 14, 2009 | 02:24 PM
Car: 92RS
Engine: LQ4
Transmission: 4L80E
have any pics of your fuel line/reg setup?
Old Apr 14, 2009 | 02:35 PM
Ronny's Avatar
This was taken day of install.
Old Apr 14, 2009 | 03:20 PM
  #42
Car: 88 IROC-z
Engine: LO3 V8 305
Pic is small can you get bigger?
Old Apr 14, 2009 | 03:22 PM
  #43
Car: 88 IROC-z
Engine: LO3 V8 305
Vafpr is the same as a AFPR??? or whats the difference??
Old Apr 14, 2009 | 03:28 PM
  #44
Ronny's Avatar
I believe it is the same. That is all I have,
Old Apr 14, 2009 | 03:32 PM
  #45
Car: 88 IROC-z
Engine: LO3 V8 305
so what kind of afpr should i be looking for with my setup. search in the tbi thread i made a posting with my car, and all i did so far.
Old Apr 14, 2009 | 04:05 PM
  #46
Ronny's Avatar
Aeromotive is best and most costly. Check EBay. Several users bought VAFPR there. Turbo City offers one as does Holley. I recall Extreme EFI Xtreme? has one too. I thought GM offerred one too for TBI and I bought one years back <$50. gmpartsdirect.com rockauto.com. Might be Marine application only currently.
Old Apr 14, 2009 | 04:09 PM
  #47
Car: 88 IROC-z
Engine: LO3 V8 305
Looking to put this wiht my holley projection soo what do you prefer?
Old Apr 14, 2009 | 04:28 PM
  #48
Ronny's Avatar
Easy. Aeromotive. #13301 $120.00 Summit
Old Apr 14, 2009 | 10:15 PM
  #49
Car: 88 IROC-z
Engine: LO3 V8 305
little on the pricey side 127.95 any other companies make 1 for TBI setup?
Old Apr 15, 2009 | 07:33 AM
  #50
RBob's Avatar
Car: check
Engine: check
Transmission: check
Do you have the Holley TBI unit? The FPR on those should already be adjustable, and from the top side. Not sure if a AFPR set up for a GM TBI unit would bolt on either.
RBob.
