90 tbi on an L31
Old Apr 8, 2009 | 02:52 AM
fastslvblkcar's Avatar
90 tbi on an L31
hey guys glad to join and had a question about my setup to see if there are any suggestions for me appreciate the help.
i have a 90 350 tbi with flat top pistons a cam to big for the ecm a set of ported and pollished L31 heads and a thermomaster hypertech chip i also have the old chip in a box at work. i am going to build a new engine but my question is that i am going to use a 98 vortec block bored .030 over probably the same heads and intake but wanted to put a roller cam in it that i might be able to avoid buying or tunning another ecm chip. i am looking for torque and at low rpm (1000-2500 or so). also have 3.73 gear ratio. any suggestions?
Old Apr 8, 2009 | 06:23 AM
TXBowTie40's Avatar
Re: 90 tbi on an L31
Read "BUDGET TBI BUILDUP" in the sticky section above. Fast355 goes into great detail about how to build a low cost TBI 350 using parts you mentioned.
Old Apr 8, 2009 | 10:18 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
EBL = No chips, but you'll have to tune it - see previous post and others that cover Vortec head build ups:
https://www.thirdgen.org/forums/tbi/...oker-plus.html
There is no way to avoid 'some' tuning as no two engines are alike.
//RF
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
FormulasOnly
Jul 23, 2018 08:47 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Gordonr1973
Sep 29, 2015 11:59 AM
