getting gas to tbi but no gas coming out of injectors
Old Apr 13, 2009 | 04:21 PM
91camaroguy's Avatar
have a 91 camaro tbi 305. I am getting gas to the throttle body however nothing is coming out of the injectors. It just died on me out of know where the other day and the check engine light is on now. Do guys think its something in the tbi that blocking it or is it something electrical? It does has good fuel pressure so its not the pump.
Old Apr 13, 2009 | 07:00 PM
dr.fiero's Avatar
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Re: getting gas to tbi but no gas coming out of injectors
You could have a cacked ignition module.
If there's no feedback pulses to the ECM, it doesn't know the engine is rotating.... so it won't fire the injectors (even though the portion of the module that fires the plugs is still alive).
You DO have spark right???
Old Apr 14, 2009 | 06:56 AM
whitelightnin92's Avatar
could also be the pick up coil. injectors fire off or disributor reference pulses.
Old Apr 14, 2009 | 07:51 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Have your ignition module tested, most major auto parts stores can do this.
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
Bradsaundry
Aug 12, 2015 12:34 AM
