My 88 Iroc-Z...Looking for info and suggestions
Old Apr 14, 2009 | 01:37 PM
killacamaro's Avatar
Car: 88 IROC-z
Engine: LO3 V8 305
Transmission: T5 W/ Stage 2 Clutch
Hey guys, well Im back and So is my baby. She has been sitting for 2 years now after My rebuild. Well I was thinking of selling her, but I am gunna keep her. So I am here looking for help to finish her and get her back to normal.
I have done these modds, Tell me what you think so far, and what next to do and what I should do in the future, Yes I know she is a 305, But cash is tight! Not trying to do any other engine modds unless they are cheapo or free!!! HEhehe suspension or car materials yes.
Well here you go guys:
LT1 cam, Springs
New Timing Chaing and sprocket
New timing cover
180 high perform thermostat
High flow water pump, nw alt , ps pump
No a/c took it all out
Holley projection TB
Edelbrock rpm intake mani
Open air element
New dizzy,wires, spark plugs
All new front suspension Struts, endlinks, swaybar, and other ES links
New brakes, rotors, calipers, ss brake lines,
March Underpulleys crank and alt
Now I changed her from serp to V belt setup. Does any1 know the size of the 2 belts I will need?
I am looking for pics on all vacuum lines on the car, also the electronic schematic on the wiring harness of the engine.
also does any1 know how to run or how should i run a CSI Tube style overflow tank for antifreeze?
Now if my gas gauge doesnt work how come? it workd b4 i cyphoned all gas out of tank. then i filled her didnt work, so i then went to replacing the fuel pump, and still nothing
My temp gauge doesnt work either, so i bought an after market one and installed her works great.
Now will be TBIchips enough of a flash or should i find someone who knows how to do EBL?
WHen i replace the rear end, what kind should i get??? and what parts to replace back there while doing the suspension?
How do i go by tightening the E brake??
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
BWilcox
Sep 20, 2015 12:19 PM
R13_Braz
Sep 18, 2015 05:00 PM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
