i bought a aldl cable- getting started
Old May 7, 2009 | 10:57 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
i hooked everything up and using winaldl software, it reads my ECM. everything works, now i have to learn how to understand all of the data. i understand some of it, but is there a good source of information on all of this. i would like to fully understand all of the data. also, does this give you the same information that a shop scanner provides? if i does, im curious why shops would spend several thousand dollars on a snap-on scanner when the same information is avaible using a used $70 scanner and a $60 cable? it seems to provide a wealth of information. some of it which i dont fully understand. i soon plan on installing a 350 in my car, and im hoping that this will a very usefull tool. the swap im doing is a jasper reman engine, its punched out 40 over, and im going to use an edlebrock perform camshaft sold as computer compatable, heads will remain stock(for now). i also have the 350 tbi unit with the proper size injectors.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
