Timing: Loss power from 800-1500rpm
Old May 14, 2009 | 11:18 AM
Dmity Kiev's Avatar
Car: Firebird 91
Engine: Vortec 350 224/230cam, ported head
Transmission: TH700r4 with vette servo,hd oil pum
Axle/Gears: now 3.73 posi old 3.23 posi
Initial timing is 7 . After 1500 Rpm car runs awesome but from 800 to 1500 she loss power , no quick acceleration , also cant do a burnout (posi, rear disk brakes)what timing must be on vortec GMPP heads in range of 800-1500-2000 rpm, BLMs seems to be good around 130-132 . 6965 ECM heres some tables that i try on last few days. http://img12.imageshack.us/gal.php?g=vortec3.jpg
Old May 14, 2009 | 01:31 PM
Dmity Kiev's Avatar
Car: Firebird 91
Re: Timing: Loss power at WOT from 800-1500rpm
Maby this table will be better ????, uf vortec dont like big timing then why a stock vortec table that Rbob posted have 45-34 degrees at WOT ib 40-100 KPa . what table is really for vortec ?
Attached Thumbnails Timing: Loss power from 800-1500rpm-1985montecarlossl69305timinggraph.jpg
Old May 14, 2009 | 01:37 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by Dmity Kiev
Maby this table will be better , uf vortec dont like big timing then why a stock vortec table that Rbob posted have 45-34 degrees at WOT ib 40-100 KPa . what table is really for vortec ?
I think it may have been Fast355 that posted the Vortec table info. However, 40 Kpa is not WOT. The WOT timing is in the 90 to 100 KPa range.
40 KPa being light cruise an engine can use more spark timing. This is because the density of the air/fuel mix in the chamber is much lower. And takes longer to burn.
This thread has some Vortec engine SA tables:
https://www.thirdgen.org/forums/diy-...ark-table.html
With the last post having a link to a thread that shows RamJet SA tables. The RamJet engine used Vortec heads.
RBob.
Old May 14, 2009 | 02:28 PM
Dmity Kiev's Avatar
Car: Firebird 91
Also is there some free software that can show actual realtime timing ?
Old May 15, 2009 | 09:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You would need to patch the ALDL stream with the SA location. Then do some math on the value at the scan tool. In the "Come in for a free tune" thread it is explained. However, the lcoations are only there for the '7747 and '8746 ECMs.
RBob.
Old May 17, 2009 | 04:45 AM
Dmity Kiev's Avatar
Car: Firebird 91
maby someone have similar engine and can show his SA table ?
theshackle
Sep 17, 2020 08:26 AM
formula_novice
Sep 5, 2015 03:58 AM
FreeSpirit
Aug 29, 2015 05:47 PM
Warlocksirix
Aug 29, 2015 11:36 AM
sailtexas186548
Aug 24, 2015 10:11 PM
