Useful tip- swapping TBI into an older vehicle
Old May 17, 2009 | 10:27 AM
gregs78cam's Avatar
Car: 1978 Camaro
Engine: 385 Dual TBI, '7427
Transmission: 4L80E
Axle/Gears: 4.10, Posi
I posted a question this last winter about the IAC not working in my '74 truck that I had swapped a TBI 350 into. It turned out to not really be an IAC problem. When putting the engine in I hooked up the ignition wires in the harness to the igntion wire in the truck's engine compartment, I even checked it to make sure i got 12V when Key on. However I did not realize that the wire was a little different. It was a steel resistor wire, and while testing it with a DMM it showed 12V, when a load was applied to it the voltage dropped substantially. I found this out by using WinAldl on the vehicle which showed a flag "low voltage - IAC inhibited". That small piece of info led me to the resistor wire that is common on older vehicles. Once full battery voltage was applied to the wire the engine purred like a kitten. I hope this helps someone else. Thanks Rbob and others who tried to help.
xkingcodex
Feb 12, 2020 07:43 PM
Infested
May 22, 2018 11:56 PM
Dwayne614
Sep 28, 2015 08:33 AM
E Rod
Aug 28, 2015 05:17 AM
GVMV
Aug 16, 2015 08:01 PM
