metal or aluminum in oil?
Old May 29, 2009 | 08:42 AM
tattooeddiva's Avatar
Car: 82 camaro unique
Engine: 327 out of a 68 vette
just found out that i got aluminum or metal in my oil, whats the cause for that. mechanic told me i need a freezeplug, and altenator. can anyone help me out here?
thanks so much in advance
Old May 29, 2009 | 10:10 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: metal or aluminum in oil?
If the metal is aluminum,you probably have a badly
worn timing chain(the original cam sprocket is
aluminum with plastic-coated teeth),or a piston
problem(very rare). If the metal is iron(sticks to a
magnet) the camshaft is failing. Either problem should
fixed ASAP as the particles will wear on the oil pump
and cylinders-if either or both problems are present,
car will run much better after the repairs
Old May 30, 2009 | 02:33 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Neither of those things will fix the oil contamination. I assume your battery doesn't charge right and you have water/antifreeze leaking from your block. If not, find a new mechanic.
Old May 30, 2009 | 08:36 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yeah, go somewhere else.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
