TBI pump to TPI pump?
Old Jun 11, 2009 | 01:11 PM
WagonmasterRuss's Avatar
Car: 1993 Caprice Classic "Woodie"
Engine: 350 TBI W/EBL Flash
Transmission: 4L60 S10 converter
Axle/Gears: 8.5, Torsen T2, 3.73s
Is this a straight swap? Fuel line diameters the same? Thanks,
Old Jun 11, 2009 | 02:53 PM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: TBI pump to TPI pump?
Yep, drops right in, at least mine did (Delco EP241). You can/should just go and buy new EFI high pressure hoses and clamps anyways, or use the one that come with the pump.
Anyways, absolutely recommended swap! Good luck on getting that tank to drop out though >.<
edit: am i reading it right, your using a Ford AOD trans behind your 350? (which i guess is an sbc at least )
Old Jun 11, 2009 | 02:58 PM
No... It's a 4l60. Better edit my "Details"
Old Jan 22, 2010 | 10:27 PM
Looks like I need to do the pump now,
What is the parts list?
Pump#
sending unit for sure
what about the harness?
Old Jan 23, 2010 | 08:05 AM
ownor's Avatar
Engine: LS1 / L03
well on the pump assembly of my '89 L03 i just put the pump in there, along with a grommet, new hoses, clamps, and filter sock. don't remember anything else was needed than what came with the pump!? as said the p/n is EP241, you can also get it on ebay.
Old Jan 24, 2010 | 09:36 AM
Pump#
Thanks guys
Old Jan 24, 2010 | 05:48 PM
Found it all at Rock Auto
EP376 - Electric Fuel Pump ('94-'96 Caprice)
FLS - 1020 sending unit (Wagon)
Pricey..... But with 200K on the car, some stuff has to be replaced...........
Now I'll be able to do the LTI Cam, CFM-tech TB and 9C1 injectors
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
evilstuie
Jan 9, 2020 08:29 PM
TreDeClaw
Aug 14, 2015 06:58 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
