Hard Start and Hesitation
Car: 1988 Pontiac GTA
Transmission: 4 spd automatic
Ok I have 2 problems:
1. The days in Charleston are now nice and hot. When the car sits at work for 8-9 hours and I go to start the car it turns over fine but acts like it isn't getting fuel. What I have noticed is that if I turn the ignition on and off 3-4 times (leaving it "on" a few seconds before turning off) it will start right up. It also starts just fine in the morning. Ideas?
2. My car is also slightly hesitating during medium acceleration. If I am going about 35-40 and accelerate to 55-60 I can feel a slight hesitation as I accelerate (almost like the car has a pulsation or tugging feel to it). I have also noticed that if I am running the A/C that after 5-10 minutes if I pull to a stop the car almost acts like it is going to cut off and if I go to accelerate it almost shuts off. Ideas?
Thanks,
Jeff
Thanks,
Jeff
Re: Hard Start and Hesitation
I am adding another link I had started to what I thought was a separate issue, but I believe now are one in the same:
https://www.thirdgen.org/forums/tech...r-now-car.html
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
omg i feel your pain. im having a similar issue with my car as well. in your case it kinda sounds to me that you are losing fuel pressure when the car sits
