TBI budget build question (timing setup)
Old Jun 26, 2009 | 10:27 PM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
In the budget build, on the vortec motor, if I switch out the timing setup (its a crank senor setup) to the one he suggest, and the cover he suggest wont work together according to what Ive read. I've done some searching, but came up with nothing. What would you do there? Iv'e been told that I can probably just use a regular aftermarket cover with that timing setup, but I want to ask you guys first.
Thanks for all of your help!
Old Jun 29, 2009 | 01:49 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: TBI budget build question (timing setup)
I just got one from summit. I ended up with a two piece one so if I want to pull the cam I can w/o dropping the oilpan, but it leaks slightly.
Old Jun 29, 2009 | 06:38 PM
vt89rs's Avatar
Car: 89 Camaro RS, 79 Camaro z28
Engine: 385 stroker
Axle/Gears: 3.23 posi borg warner
i have a edelbrock double chain for my setup and just used a stamped steel cover that says chevorlet and it works fine for me
Old Jun 29, 2009 | 07:26 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
Yea, I figured everything would be ok with a regular cover, but from experience It's always better to make sure. Thanks
MustangBeater20
Oct 29, 2022 09:20 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
camaro71633
Sep 1, 2015 10:24 AM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
