Is there a fuse for the fuel pump?
Car: 91 RS
Engine: 305 TBI
Axle/Gears: stock non-posi
Re: Is there a fuse for the fuel pump?
is it running when you turned the car off? i had that issue and just disconnected the negative on the battery. I couldnt find a fuse, i believe its a relay, ive yet to locate.
Car: 87 Camaro
No its just that theres a mechanical fuel pump and the in tank pump and I just wanna unhook the in tank and see if it'll still run. If not I'll hook it back up. I guess I'll have to get it on the lift and have a look thats kind of annoying that theres no fuse..
Car: 87 Camaro
Ok so I found that thing you were talking about about the axle and unhooked it and I think it was the relay but now my gas gauge just reads full all the time lol so should that be happening or did I get the wrong thing?
Car: 1992 Camaro RS
Engine: 305 TBI
You unplugged the entire fuel gauge sending unit. The fuse box should have a fuse slot marked as "F/P". If not then unplug one relay at a time until the fuel pump does not run.
92camaroJoe
Aug 13, 2015 06:07 AM
