Needs starting fluid to start
Old Aug 14, 2009 | 09:23 AM
robster66's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 305 T.B.I.
Axle/Gears: 2.73 Open Diff
This is driving me nuts, I have no check engine codes and I have no idea what it could be. I tried changing the ECM but the one I changed it with might be bad. I have changed many sensors..
-TPS
-CTS
-MAP
etc..
The injectors will not fire initially unless you start it with starting fluid and than it will fire up and run perfectly fine until it warms up and enters closed loop mode I believe. None of my friends can figure it out either.
Old Aug 16, 2009 | 03:06 AM
mroth2008's Avatar
Car: 2001 Mazada Protege es
Engine: 2.0L dohc
Transmission: G-15m-r
Axle/Gears: 4.10
Re: Needs starting fluid to start
something to do with the choke it seems to not be giving it any gas on start up so I would start thier
92camaroJoe
Jul 29, 2023 07:57 PM
backtothe80s
Sep 5, 2015 12:39 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
killer777
Aug 8, 2015 02:47 PM
