question about $0D_MAF mask
I have a 94 C1500 truck. I'm currently swapping a TPI intake onto my TBI motor and don't really want to swap my pcm. I was wondering if the 16197427 pcm can run both batch fire and the $OD MAF coding at the same time.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: question about $0D_MAF mask
The TBI MAF code is specifically written for TBI and its requirements. The stock $0D code will handle the TPI fine with the needed mods to the memcal, mask and injector driver sense resistors. Unlike TBI, SD works well with dry flow MPFI intakes and the PCM can do batch fire just like a TPI ECM. Do some searches on the DIY-Prom board. This has been covered quite a bit.
