Fuel or timing?
Old Aug 24, 2009 | 06:20 PM
kenwa26's Avatar
Fuel or timing?
I have a 1989 camaro with a 350 swapped in place of the 305 by the previous owner, my issue is this the car starts and idles fine, when you give it throttle it bogs and wants to die unless you feather the throttle, i pulled the air cleaner to check and see what its doing, at first i thought i had a fueling issue, but it is "backfiring" through the throttle body, so im thinking the timing is an issue. However the motot doesnt appear to have a timing tab pointer on it, is that something these were built without? is there a method for reading the timing I am unaware of?. Oh I havent checked the injector part #'s but overall it appears a good job was done on the swap with the proper 746 computer installed and everything.
Old Aug 24, 2009 | 06:35 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: Fuel or timing?
It's a fuel delivery problem.
I tried to start my car once (to get gas) and it was extremely low already, and I poured a little gas into the TBI unit to prime it and though it go the engine running, it was running horribly, you had to feather the gas to get it to stay running, but if you stayed on the throttle it would start to die.
Check to make sure the injectors are spraying in a proper "cone" fashion.
Old Aug 24, 2009 | 07:00 PM
kenwa26's Avatar
Re: Fuel or timing?
injector spray pattern is good, as i said it starts and idles perfectly
Old Aug 25, 2009 | 04:49 PM
Etromania's Avatar
Re: Fuel or timing?
I Just had an issue with mine to where it idle fine, and ran great untill it reached norm temps, then it would backfire like mad through the tbi whenever you gave it gas,untill it would die,
i changed the coil and that fixed it, the other coil was going bad, thats a cheap fix (18$ at napa ) id say start there, with ignition.
Old Aug 25, 2009 | 08:30 PM
kenwa26's Avatar
Re: Fuel or timing?
well im going to start with a timing check, but the batteries in my timing light were dead
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
