where does this vacuum line go? pic inside
Old Sep 7, 2009 | 10:48 PM
crusinman2002's Avatar
Car: 1989 Camaro RS
Engine: 305 for now
Axle/Gears: stupid open diff. 2.73 i think
as the title says, where does this vacuum line go? just noticed it cause i had the air filter housing off doing an oil pan gasket change. (which turned into a nightmare by the way, everything that could go wrong did). on mine, the line is about 6 inches long and doesn't seem to have a place to go, unless if i just cant see it... lol... oh... car is an 89 camaro rs 305 tbi. thanks in advance, a vacuum leak might be the cause of my fuel problem. red arrow pointing at line in question.
edit: the pic shown is not my tbi, got the pic off the web and put the arrow in
Old Sep 8, 2009 | 12:13 AM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: where does this vacuum line go? pic inside
Is there an Emissions sticker on the front of your hood? If yes, it should have a vacuum hose connection diagram on it.
Old Sep 8, 2009 | 12:26 AM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
on mine it goes to the air cleaner.
Old Sep 8, 2009 | 02:23 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
That line usually provides full time vacuum to AC controls. Look for a vacuum tank that might be leaking.
//RF
Old Sep 8, 2009 | 03:37 AM
Car: 1989 Camaro RS
Engine: 305 for now
thanks for the help, will look to see if i have a sticker showing under the hood. will check the bottom of the air cleaner assembly here in a few hours. the line doesn't look long enough to get anywhere near the ac stuff, but i will see if i have a hose laying that might have gotten cut
Old Sep 8, 2009 | 03:41 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
S port goes to the Thermac activator in the air cleaner.
Old Sep 8, 2009 | 01:23 PM
Car: 1989 Camaro RS
Engine: 305 for now
thanks thomas, thats where it went, the fitting is a bit hidden but i found it. thanks for the help everyone
Old Oct 17, 2009 | 05:53 PM
2LTCamaro's Avatar
I got an aftermarket open air cleaner assembly. Where do I put that line since there is no longer a place for it?
Old Oct 17, 2009 | 07:18 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
cap it off at the TBI so there's no vacuum leak
Old Oct 18, 2009 | 01:09 PM
2LTCamaro's Avatar
ok thanks!
Old Oct 18, 2009 | 01:18 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
If you need any help with the aftermarket air cleaner, I just did mine last month. If you got the edelbrock 14 inch then you might have a problem. On mine the bolt was too short to get the wing nut on so I had to shorten the spacer a little and it fit. Putting that on is a great investment because mine runs smoother, cleaner and also noticed a little more low end torque. Not much but noticable. Good luck bro.
Old Oct 18, 2009 | 04:34 PM
2LTCamaro's Avatar
I actually got one off ebay. Paid $72 is is exaclty like the K&N Xstream. Same flow as well. Even had a spot for the sensor. While on the subject I removed the AIR tubes and the bypass valve. Any idea what other vacuum problems I may run into? I kept the charcoal canister but the car is shifting hard and rough. especially when cold. There is a sensor on the passenger side of the air cleaner that has line that plugs into it. Where does that go? Also that little piece that had 3 lines into it broke so I bought a 3-way valve. Does one of those plug into the little piece that is right behind the air cleaner?
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
cstrobel65
Aug 15, 2015 10:19 AM
apie2546
Aug 10, 2015 05:43 PM
Kaweh
Aug 9, 2015 02:54 PM
