where is the mass air flow sensor?
Old Sep 19, 2009 | 10:05 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I need to know where the maf is located on a 305 tbi. Any input would be appreciated.
Old Sep 20, 2009 | 04:49 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: where is the mass air flow sensor?
No MAF. The MAP, follow the vaccum hose on the rear of TB (F port) it goes to the MAP, on top of the firewall.
Old Sep 21, 2009 | 09:10 AM
kcb37's Avatar
Yep.
Your MAP Sensor like said, should be on the firewall on the passenger side of the car.
If I remeber correctly the plug has 3 wires, may be 4 but pretty sure it's 3 wires.
And a single vac line.
Old Sep 21, 2009 | 11:08 AM
I'll check it out. I replaced the o2 sensor yesterday, and what a pain in the a**.. I got to it from under the car. I am still getting a check engine light. The guy who sold the RS to me gave me an o2 sensor, and said it needed to be replaced, so I replace it. Seems to run good though.
Old Sep 22, 2009 | 09:38 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
have you pulled the codes yet to find out what problem the light is saying you have? Throwing parts at a vehicle drains the wallet reallllly quick.
Old Sep 22, 2009 | 10:22 AM
Ronny's Avatar
As stated pull codes and check for disconnected vac lines or defective vac lines(split)
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
