Air Silencer ring
Old Sep 30, 2009 | 11:35 AM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Air Silencer ring
Where exactly is the air silencer ring...i removed the ring that is under the air filter itself but is wasn't welded on or anything, is this the right "ring" its about 5 inches wide
Old Sep 30, 2009 | 11:36 AM
Eustace16's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Re: Air Silencer ring
/\-----Is that it in the pic?
Old Sep 30, 2009 | 01:24 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Your 2nd pic shows up, not the first.
Yes thats the ring.
Old Sep 30, 2009 | 03:46 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
This is the silencer ring, to remove. Of course if you can fab a base to get rid of the pacer ring and allow a little more air from the side to enter the tb, thats a good idea.
Attached Thumbnails Air Silencer ring-dsc03414.jpg   Air Silencer ring-dsc03417.jpg   Air Silencer ring-modified-stock.jpg
Old Oct 2, 2009 | 06:28 PM
jbk88sc's Avatar
Attachment 186179
This photo is the stock air cleaner spacer ring. It is used to raise up the stock "drop base" to clear the TBI injectors, you can not use the stock air cleaner or any other drop base type of air cleaner w/o this ring. If installing a non-drop open air cleaner you dont need the ring.
Old Oct 2, 2009 | 09:55 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
This did nothing but make my throttle get stuck a few times, I noticed no benefit.
Old Oct 6, 2009 | 02:37 PM
jbk88sc's Avatar
Attachment 186179
This is the "spacer ring" used to lift the stock drop base air cleaner above the injectors. If you go with a non-drop open air cleaner then you don't need this ring.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
