good cam
Old Nov 7, 2009 | 01:47 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
good cam
Hi i am gonna be swapping in a 350tbi in my camaro after my 305 gives out and i was wondering if there is any good cam that i could put in the 350 to give me some good hp also still be a daily driver. Also if i could use the stock lifters would be better since i already bought new ones. Or any recommendations of what mods i could do to the engine.
Old Nov 7, 2009 | 02:52 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: good cam
make sure to use a cam with good vacuum. you might need the 350 throttle body or injectors. most mods to to fuel injection engine are programming and exhaust upgrades. you don't want to loose your low speed torque.
Old Nov 7, 2009 | 02:55 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
which cam you think would be best for that any cams that you know of
Old Nov 7, 2009 | 03:01 PM
Re: good cam
my s10 has a summit 1102, my 84 z28 has a crane. i think its an old energizer cam. both would work well with fuel injection. just find a cam that rpm range starts around 1000-1200 rpm and wide LSA, duration @0.50 is under 220 degrees
Old Nov 7, 2009 | 03:02 PM
Re: good cam
http://www.summitracing.com/parts/SUM-1102/
Old Nov 7, 2009 | 03:31 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
Ok thank you for your help
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
