Problem After FPR Mod
Car: 92 RMW
Engine: L05/350
Axle/Gears: 3.23Posi
92 RMW w/L05. I checked pressure before mod 11psi, I had no codes or other issues.Bumped it up to 12.5 now it's pinging on the idle and the idle is@ 1250rpm and seems to take a while to come after start up.Also is pinging under 2.000rpm no matter what gear it's in.
Car: 92 RMW
Engine: L05/350
Re: Problem After FPR Mod
You would think that it would be under load it would happn' not on the idle.not sure new to the wholeTBI thing
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
I hate to be this way, but it sounds like something didn't go back together quite right, leaving you with a vacuum leak or non-functioning EGR.
Car: 92 RMW
Engine: L05/350
Everything is hooked up.ran it today without scann tool pluged in and it ain't doing it no more seems to be running alright.
LT1Formula
20
Nov 14, 2015 12:02 AM
