help high idel
Old Nov 19, 2009 | 04:47 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
help high idel
i have a problem i have a 91 camaro with a 383 and a whipple supercharger and a 54mm tb and 90lbs injetors with a custum prom from tbichips. my promblem is it is ideling at 3600 rpm and not going down, what can be my problem????? anyone?????
Attached Thumbnails help high idel-me2009-352.jpg   help high idel-me2009-350.jpg
Old Nov 20, 2009 | 01:32 AM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: help high idel
first things first, can you run a stock hood like that and do you have any more pics!
are your throttle blades closing all the way? if they are, then I would check the IAC motor, and check for vacuum leaks.
Best of luck-
Eric
Old Nov 20, 2009 | 06:51 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: help high idel
I doubt a tbi ECM can run that correctly, though I have only gathered information from the internet. The EBL would be plug and play http://dynamicefi.com/, you will also need a 2bar MAP sensor.
Wish I had such a toy to play with.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Zell1luk
Sep 29, 2015 10:36 AM
