Need Help!!
Old Nov 30, 2009 | 12:25 AM
hdj89's Avatar
Need Help!!
Alright so I hope im posting in the right section for this but here it goes.
I have a 92 camaro rs tbi. I just recently did a cam swap and new springs aswell. Now I got the car all back together and go to start it and nothing. Wont turn over or anything. I noticed that my engine light will not coming on when turning the key to the start position. My fuel pump will not prime, and my starter doesnt even click. I do know that when I primed my oil pump that fuel came out the lines, for whatever reason. I just need alot of help with this. Oh and also my hatch latch also stopped working, I have checked all the fuses and relays and they are fine. I even pulled out my ecm and inspected the board, its all good looking to me.
Old Nov 30, 2009 | 02:22 AM
livinforhim's Avatar
Car: 1990 Camaro RS
Engine: 3.1 V6
Transmission: 700-R4
Re: Need Help!!
Check all your grounds first. sounds like nothings getting power. and regarding your hatch if you'll take the plastic peace covering the motor and inspect it, you might find that the end of it has broken off. its really common. especially if you slam the hatch with bad hydrolics, it breaks the motor. you may have to play with it till you get it to engage again, (if its not clearly broken)
Old Dec 1, 2009 | 01:31 AM
hdj89's Avatar
Re: Need Help!!
dude that was exactly the problem, i missed a ground wire, now everything is good.
