Injectors not spraying
Im having a problem with my injectors on my TBI. I just replaced the fuel pump inside the tank because i was getting very little pressure at the shradder valve. Im now getting sufficient fuel pressure at the valve but i can not get the injectors to spray. Im getting voltage at the injectors and the resistance is good. I bypassed the antitheft relay for the car being able to turn over without the chip key or whatever. I just connected the constant voltage wire to the one that goes to the clutch switch, but i didnt do anything with the other two little wires. Is that a problem that would cause the injectors to not spray? Also i put a little gas down the throttle body and it started of course but the injectors actually sprayed a little. Any help?
