injector pulse
Old Jan 18, 2010 | 07:10 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
injector pulse
i have a 92 rs that keeps quiting on me it will run for a couple than just quit.than wont start back up for about half hour or more.when it quits it is loosing injector pulse does anyone know what might be causing this?
Old Jan 18, 2010 | 08:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: injector pulse
For a SWAG I'd say either ignition module or pickup coil in the distributor.
RBob.
Old Jan 30, 2010 | 10:03 PM
bigAboss's Avatar
Car: 1991 camaro rs
Axle/Gears: 94 z28 rear with stock 3.42's
Re: injector pulse
i have a 92 with a 350 tbi, i start it up and the injectors spray for a few seconds then stop while cranking, and dont spray agian unless i take the injectors out, take an air hose to them and install them? it hasnt ran yet due to the injectors not working right, replaced them and still the same, could it be the VATS system? the module on the distributor? im lost please help!!!!
92-Formula
Dec 12, 2015 10:34 PM
327IROC85
Sep 23, 2015 12:11 AM
rubyred88
Sep 17, 2015 02:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
Ranbo108
Sep 9, 2015 12:20 PM
