What should my timing be set at?
Old Jan 24, 2010 | 03:53 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I know this is probably an amateur question, but what should my timing on my L03 be set at?
Old Jan 24, 2010 | 05:41 PM
anthonyrs's Avatar
Car: 1991 CAMARO RS,1997 FORD EXPLORER
Engine: NO MORE 305. 350 NOW
Axle/Gears: 273 NEED NEW ONES
Re: What should my timing be set at?
Old Jan 24, 2010 | 06:39 PM
Engine: 350 S/B
Is that with the wire up on the firewall unplugged?
Old Jan 24, 2010 | 06:44 PM
anthonyrs's Avatar
Yes. Look on your hood it should tell you to.
Old Jan 24, 2010 | 07:02 PM
Engine: 350 S/B
It does say 0 on the hood. Thanks Anthony.
Old Jan 25, 2010 | 10:13 PM
Engine: 350 S/B
O.k. I reset my timing to 0 and it seems to be running better now. But when I get out of my car after turning it off it smell as though it's running a little rich. Is this normal?
Old Jan 26, 2010 | 08:23 AM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I get a wiff of gas with mine too, but it is near the gas tank. Might be a hose or in your case that stupid canister behind the drivers headlight.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
