350 tbi headache
Old Jan 30, 2010 | 10:12 PM
bigAboss's Avatar
Car: 1991 camaro rs
Axle/Gears: 94 z28 rear with stock 3.42's
350 tbi headache
i have a 92 rs with a 350 tbi in it, now i just bought the car mind you. i tried starting it today and i wasnt getting any spray from the injectors. i took them out and took an air hose to them and re-installed, tried starting it agian and they sprayed for a sec and that was all she wrote. wouldnt spray anymore until i took them back out and re-installed them, would this be a VATS issue or the module? PLEASE HELP!!
Old Jan 30, 2010 | 10:52 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
Re: 350 tbi headache
how does the fuel pump sound? try seeing if you're even getting fuel. pull the line and see how much fuel comes out, or just test the fuel pressure (about 12 psi)
if it's not much, it could be a clogged fuel filter.
Old Jan 31, 2010 | 08:23 AM
bigAboss's Avatar
Car: 1991 camaro rs
already tested and all is good
Old Jan 31, 2010 | 10:36 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Check for codes. Does the SES light come on? The car shouldn't even turn over if its vats. Just the red security light will come on.
Old Jan 31, 2010 | 05:24 PM
bigAboss's Avatar
Car: 1991 camaro rs
thanks for all the help, i figured it out, measured the resistence on the key and cut the vats wire and soldered in a resistor with the same amount of ohms and fired right up and runs like a raped date
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
