distributer
Old Feb 9, 2010 | 03:37 PM
effinbird's Avatar
distributer
anyone have any advice on a good aftermarket performance distributer. The 350 i purchased and am building up didnt have one in it. or would i be better off just getting a stock one and upgrading the components?
Old Feb 10, 2010 | 10:11 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: distributer
Originally Posted by effinbird
anyone have any advice on a good aftermarket performance distributer. The 350 i purchased and am building up didn't have one in it. or would i be better off just getting a stock one and upgrading the components?
My preference has always been stock GM small cap distributors. With an OEM GM ignition module (even if already used). Make sure that the shaft bushings are OK. Then pull it part and clean it. If the shaft is stubborn (varnish deposits) use some 2+2 gum out sprayed in from the bottom.
Replace the pick up coil (new one), and use new heat sink compound under the ignition module. Reassemble and use it. Note that the dimple on the gear goes in line with the slot on the top of the shaft. Can also shim the shaft end play for 15 - 20 thou (NO tighter).
RBob.
Old Feb 10, 2010 | 11:06 AM
effinbird's Avatar
Re: distributer
alright thats what ill do then thanks for the help
db057
Apr 28, 2019 07:45 AM
Gunner242
Dec 25, 2015 04:49 PM
drptop70ss
Oct 4, 2015 09:44 PM
dusterbd
Sep 29, 2015 08:40 AM
pimprs
Aug 24, 2015 11:20 PM
