Fuel pressure gauge not working
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I just finished installing braided hose fuel lines between the flex hose by the alternator and the TBI unit.
I installed a fuel pressure take off adapter (1/8 npt female) and gauge (1/8 npt male) at the connection near the alternator. When I start the car, the gauge doesn't seem to work (stays on zero).
I do believe I have the gauge on the inlet side since the hose its connected to runs to the passenger side opening on the throttle body. The car runs fine so I know the hoses aren't reversed.
Do I have a bad gauge or do I need to move the adapter and guage closer to the TBI unit in order to get a reading?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Fuel pressure gauge not working
Make sure you have it on the larger hose, that is the feed side. Other than that, yeah it sounds like you got a bad gauge. It should give you a reading anywhere in the line on the feed side. I've had them connected just after the filter under the car and gotten a reading from it(was checking to see if the filter was clogged). As close as possible to the TB is the most accurate place, but anywhere close by should work too.
9192camaro
16
Feb 3, 2019 12:21 AM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
