Too much air?
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Too much air?
Since early TBI vehicles are not equipped with a MAF sensor if you installed a functional ram air on one would it run too lean because it is only programmed to deliver a certain amount of fuel and now you are shoving a bunch of air down the throttle body?
Re: Too much air?
You assume ram air works
But yes improving the breathing on any motor will tend to lean out the mix at certain points under load.
A MAF car has the ability to compensate up to a point and even an SD car has O2's but at some point both will need electronic tuning.
Re: Too much air?
same question can be asked of adding a blower. If ram air increases air flow 5% the WOT would need to be adjusted in .bin(enrichen). A WB would be helpfull. CL will take care of itself.
