TBI adapter plate Question
Old Mar 6, 2010 | 07:51 PM
Cruzer Dood's Avatar
Car: Toyota FJ 40
Engine: 350 Chevy
Transmission: SM420
Axle/Gears: 3.70
Hey there. When using a 4bbl manifold on a TBI swap into an older vehicle, is there a preferance on which TBI adapter plate to use? I've found aluminum plates from Holley and Tran-Dapt, along with a steel plate from Trans-Dapt. I got a 3/4" X 6.5" X6.5" piece of alum, thought about making my own, can't be that much to it. Thanks, Al
Old Mar 6, 2010 | 08:12 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: TBI adapter plate Question
if it's a Q-jet manifold, you can get the 454 adapter from a junkyard. it's a pretty cool looking piece, but it'll add about 1 1/2 inches to you intake, maybe 2.
Old Mar 8, 2010 | 10:49 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I made my own, but I ended up with the throttle body about 1/4" farther forward than stock. I figured this might help a bit more since the blades seem to direct the mixture more towards the rear of the engine. I ended up needing to cut the clamp off the throttle cable under the dash so it would extend far enough for the linkage.
Old Mar 13, 2010 | 10:49 AM
Car: Toyota FJ 40
Engine: 350 Chevy
Transmission: SM420
Axle/Gears: 3.70
Thanks Guys. Al
MustangBeater20
Oct 29, 2022 09:20 PM
evilstuie
Jan 9, 2020 08:29 PM
dutch930
Sep 11, 2015 06:58 AM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
