hp difference in heads...
Old Mar 10, 2010 | 12:48 PM
tman-420's Avatar
Engine: 350ci
Transmission: TH350
Axle/Gears: 3.08 posi
I have a stock 72 #3790010 350ci bottom end, im going to be using an edelbrock performer cam idle-5500. TH350 stage 2 shift kit, 2000stall. i have the #3790010 block #39889881 1.72int/1.5exh heads factory 165hp Combo 8.2.1 compression, also have a set of 1990 TBI cast Iron heads 1.94int/1.5exh swirl heads, witch heads would perform better?
Old Mar 10, 2010 | 01:41 PM
Ronny's Avatar
Re: hp difference in heads...
I would sell those and buy GM performance Vortec heads and use vortec adapter plate on V carb manifold. GM Vorted are about $500 pair + ship..
Old Mar 10, 2010 | 02:27 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i have the L05 heads on my s10 and i like the torque.
69GTOby
Apr 18, 2016 02:34 PM
scottmoyer
Sep 20, 2015 11:54 AM
Numbah-1
Sep 12, 2015 08:57 PM
J.C. Denton
Sep 8, 2015 05:35 PM
greenyone
Sep 2, 2015 03:39 PM
