Edelbrock TBI intake 3704 matched to RHS Vortec heads. Can it be done??
Old Mar 11, 2010 | 07:42 PM
89junkyardgta's Avatar
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Hi all,
Here is the deal. I have my used $100 Edelbrock intake, my $500 low mileage 350 TBI and a desire for power and mileage, because gas isn't getting cheaper. Vortec heads with decent springs are hard to find in my area, most are $600 or more. RHS Vortec heads are about $750, brand new, flow a little better than GM vortecs, and come from a shop, rather than Joe on kijiji or whichever classifieds you use. RHS vortecs are also drilled for the above mentioned intake AND have an EGR port (I have to be legal), HOWEVER, ports are still all vortec, so they don't match up so great. I can easily give them the height required and there should be enough meat to seal, but the ports on the intake are a bit wider than the vortec head ports, so my gas/fuel mix is going to hit a restriction at the end of the intake runner. I am not building a monster motor, just trying to get good mileage and decent power after I lay my 305 to rest. Am I sweating nothing, or should I/could I use some JB weld or similar to fill in the intake a bit to improve the transition? Also, the other thing fueling this is Vortec TBI intakes are $300+ and the headers to match with the EGR tube run $450+, no ceramic coating, while I can get a set of ceramic coated headers locally for less than $300 and I already have the intake. This is also going in a truck, but it really wishes it was a Camaro! Thanks in advance.
Old Dec 19, 2011 | 08:27 AM
bizzybone485's Avatar
Re: Edelbrock TBI intake 3704 matched to RHS Vortec heads. Can it be done??
Hate to bring back an old post but how did this go? I have the same 3704 intake and looking into these PRo Action RHS 180cc 64cc Heads for my 355 cammed TBI
Old Dec 19, 2011 | 11:04 PM
Engine: L98, LG4
Never did it. Found a little crack in my block while cleaning it up and never used it as it was intended for my daily driver. Ports are different (I deleted my photos it seems) and likely need to be matched to be optimum, but would probably work without. TBI runners aren't as tall as vortecs. Sorry I'm not much help, but if you decide to travel that route, please post the results.
Fast355
Dec 2, 2016 06:33 PM
Keith5
Aug 27, 2015 04:37 PM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
L98GTA87
Aug 11, 2015 06:55 PM
