motor warms up and looses responsiveness
Old Mar 20, 2010 | 03:35 PM
co15say's Avatar
i have a 350 tbi motor that i put vortec heads on and everything seems to be fine but when she runs for about 30 min. or so the motor cuts out when u stomp the gas fast. if u work your way into the gas it seems fine. any ideas on what may be causing this would be great. thanks
also some details
vortec heads
BB TB with 350 injectors
edelbrock intake with adapter
no egr
stock chip
vortec fuel pump
Old Mar 22, 2010 | 04:58 PM
1988-305-tbi's Avatar
Re: motor warms up and looses responsiveness
YOUR PROBLEMS ARe AS FOLLOWS
vortec heads
no egr
stock chip
vortec fuel pump
all of this with a stock chip, why did you remove the egr? were you getting too good off gas millage or too much power, or not enough pollution out the tail pipes?
Old Mar 22, 2010 | 10:38 PM
co15say's Avatar
i have posted a request on how to run a egr with these heads and i can not get any info and yeah i know the chip is out of tune so go post somewhere else i figured out the problem was fuel
Old Mar 24, 2010 | 07:56 PM
the egr comes off the intake manifold. not the heads if your intake doesn't have provision for an egr, by a different one or....
if you know what you are doing..... you can drill and tap a hole to run a hose off of to run to the egr valve
Old Mar 24, 2010 | 11:36 PM
co15say's Avatar
i think i can do the drill and tap but the guy at tbichips bypassed his egr do u think that would be for the worse or better. i would need to burn a chip to do this i know but what do u think about bypassing it?
Old Mar 25, 2010 | 12:31 PM
the EGR is good, if you can use it, use it.... if you can't, tune a chip withought it
Old Mar 25, 2010 | 09:34 PM
co15say's Avatar
ok cool and also do u think the rough idle will go away with a tuned chip?
Andrew6.688
Dec 13, 2015 10:59 AM
greenyone
Aug 29, 2015 11:08 AM
cstrobel65
Aug 15, 2015 10:19 AM
stalkier
Aug 13, 2015 12:59 PM
