need help again
Old Apr 4, 2010 | 09:41 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
need help again
my camaro had been sitting for a few months (started everyday) i just started driving my camaro for 2 days and it wont keep on ..i start it and it shuts off and wont idle ...it does not smoke or knock
Old Apr 7, 2010 | 03:22 PM
Ronny's Avatar
Re: need help again
Will it idle at a slightly higher RPM? If so I would place a dime/shim under throttle stop screw and witness the spray pattern of injectors. Even conical spray should be seen. fresh fuel filter?
Old Apr 8, 2010 | 06:10 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
Re: need help again
im going to replace the filter this weekend hopefully thats it
Old May 4, 2010 | 08:22 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
Re: need help again
ok i tried the fuel filter and replaced all the spark plugs ..this is killing me its my only car i need to get this thing running in a week the car will not stay on enough to drive it just starts surges and dies sometimes it will surge for about 3 mins then die ... can anybody give me a list of things that cause this surgeing problem thanks for your help
Old May 5, 2010 | 09:17 AM
Ronny's Avatar
Re: need help again
what does spray look like? I think some will shine timing light on spray to better determine quality of spray. Any codes stored?
Old May 5, 2010 | 08:05 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
Re: need help again
im going to get the codes checked and i do not have a timing light
Old May 9, 2010 | 12:09 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
Re: need help again
ok ive changed the distributor cap and all of the spark plug wires and plugs ..my car still surges i got some throttle body cleaner and sprayed it on my car started to run a little bit but then died so i opened up the throttle body and sprayed it in while it was on ..i think my fuel pump isnt sending enough fuel to the tbi ..does this sound reasonable
Old May 16, 2010 | 11:59 PM
b72roc's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Transmission: auto
Axle/Gears: posi
Re: need help again
ok i changed every sensor but ica and tps i was getting a code 44 so i changed the oxygen sensor and now im getting a code 43 and i dont know what to do to fix the 43s problems car only works when hot but when put into gear it bogs down and shuts off ..im thinking of changing my intake gaskets is this a good idea?
