Newbie question: What are the "coil wires?"
Old Apr 8, 2010 | 12:25 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
I'm putting on an open air element cleaner and everywhere around here warns in big red letters not to let it touch the "COIL WIRES."
Are these just the wires that go from the distributor to the spark plugs, or is it something else?
Thanks!
Old Apr 8, 2010 | 12:44 PM
joshwilson3's Avatar
Re: Newbie question: What are the "coil wires?"
Probably the wire going from the distributor cap to the coil.
Old Apr 8, 2010 | 12:45 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
What's the coil? The ignition coil?
Old Apr 8, 2010 | 01:38 PM
Yes. There is a wire in the middle of the distributor cap that goes to the coil. The coil also has other wires going to it as well.
The red part "Mallory" is the coil:
Old Apr 8, 2010 | 01:45 PM
Zerocyde's Avatar
Car: 88 Camaro
Axle/Gears: 4.11
Awesome, thanks a mill!
Old Apr 9, 2010 | 09:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
The reason for the warning - most folks use a 14 in air cleaner housing for the open element, and they have a tendency to touch a plug wire on the distributor - after so long of this, the sharp edge of the chrome housing can rub though a plug wire, and thus short out and cause ignition issues.
I had the problem - I switched to a 9in housing, now no problem.
stalkier
Dec 6, 2015 11:25 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Fronzizzle
Aug 17, 2015 02:52 PM
L98GTA87
Aug 5, 2015 11:02 PM
