305 TBI stalls when hot
Old Apr 21, 2010 | 10:12 PM
RedCamaro1991's Avatar
I recently purchased a 1991 Camaro RS TBI that likes to shut off when its up to operating temperature. Sometimes in warm weather, it takes multiple cranks to start. The man I bought it from claims that he rebuilt the TBI unit and set the idle to low due to the lack of a functioning tachometer in the car. Most mechanics I have talked to say that it is not the idle causing this, but a bad air/fuel sensor, or possibly a vaccum leak. Is it cheaper to fix this or convert to a carberator?
Old Apr 21, 2010 | 10:17 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
Re: 305 TBI stalls when hot
i had the same prob but mine would stall out at maybe 210 bout there. i just put 87 octane and it hasnt done it since. but also i would replace the tbi with a carb you get more power.
Old Apr 22, 2010 | 08:52 AM
87 Octane? That is low-test regular gas.
Old Apr 26, 2010 | 10:21 PM
Car: '90 Camaro
Engine: 305 tbi
my bad i was in a rush i ment 89
Old Apr 30, 2010 | 06:44 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Coolant temperature sender, vacuum leak, map sensor.....I did the shotgun method since I did not know what the problem was..Good luck..
Glowsock
Jul 24, 2025 03:15 PM
xkingcodex
Feb 12, 2020 07:43 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Dwayne614
Sep 28, 2015 08:33 AM
