Help me identify a holley tbi unit
Old May 14, 2010 | 08:55 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
Hello,
I purchased a holley TBI from ebay (950-24S) which is supposed to be a 900cfm with 75pph injectors. However, I suspect it's a 700cfm with 65pph injectors. Is there a way to identify which unit I have?
Notes:
1.5" throttle bores
Injectors have a yellow ring
Injectors have 4247 and 5717 stamped on them
Thanks for the help!
Old May 15, 2010 | 09:40 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Help me identify a holley tbi unit
Holley used to color code the injectors (yellow ring). However, I don't recall what the flow is.
If the bores are truly 1.5", then it is a 2.8l or 3.1l TBI unit.
The 4.3l, 5.0l, & 5.7l TBI units have 1-11/16" bores (stock GM). And flow about 500 CFM @ 1.5" Hg
The 7.4l units have either 48mm or 2" bores, not quite sure on the stock ones. And flow about 650 CFM @ 1.5" Hg
RBob.
92camaroJoe
Jul 29, 2023 07:57 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
InfinityShade
Aug 22, 2015 08:00 PM
355tpipickup
Aug 19, 2015 10:02 PM
92camaroJoe
Aug 13, 2015 06:07 AM
