tbi fuel injector problems
Old May 31, 2010 | 11:27 PM
MaEllis89's Avatar
I have a 1988 Camaro with a 305 tbi and only one injector is shooting fuel. i switched the injector wiring around and the problem followed the wire. so its not the injector. what should i do to fix this problem?
Old Jun 1, 2010 | 04:01 PM
383TBI's Avatar
Car: 87 Chevy Short Wide
Engine: 383 Vortec TBI
Re: tbi fuel injector problems
You can trace the wires back to look for a break or somthing.I had this issue with mine and a terminal at the ecm for injector pulse signal had opened and causing an injector to cut out.I pulled the terminal out and closed it some.Problem solved after that.No problems ever since.
bryan623
Mar 22, 2021 06:43 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Firechicken86
Aug 12, 2015 10:07 PM
