Failed e-test major bad. Ontario
Old Jun 3, 2010 | 06:23 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
My 91 just failed horribly, 3 and 4 times the limits, talking to a few mechanics, and the guy I knew working there, they said my O2, my EGR, and my cat are pretty much fried. When I took the egr off, I noticed that when you push it in, it doesn't hold the pressure with your thumb on the vacuum tit.. Is this bad?
The O2 definatly didn't look good, $38, a brand new NTK one.. I also noticed, that my MAP vacuum line was disconnected, and probably why the car hasn't run right in a while.. Took it out for a cruise and it feels like when I first put it on the road..
So my main question is about the EGR, above.. Lemme know.
Old Jun 3, 2010 | 10:53 PM
jim_in_dorris's Avatar
Re: Failed e-test major bad. Ontario
yeah, if it doesn't hold a vacuum it is no good.
Old Jun 3, 2010 | 11:48 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
I failed an e test once by at least twice the limit, took a look under my plenum and the vacuum line on the egr had popped off when I did my slp runners. Popped it back on, passed well within the limits. A bad EGR will definitely change things
Old Jun 4, 2010 | 06:21 AM
Kevman's Avatar
Engine: 2004 LQ4
I ordered one from Rock Auto last night, $62 to my door, everyone local was around $140 - $160..
I have another question, on my intake, on the drivers side, oil seems to be pooling up, could the intake be cracked? I have brand new Felpro valve cover gaskets, and everything seems to be tight.
Old Jun 4, 2010 | 12:08 PM
norcalz28's Avatar
Spray it down with some cleaner and monitor, or you can put UV dye in the oil and trace it that way. Not likely the manifold would crack on a TBI car
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
sjorgens
Oct 1, 2015 07:54 PM
