no squirt at injectors
Old Jun 12, 2010 | 07:35 PM
92orangestripes's Avatar
Car: 2000 expedition 5.4
Engine: .020 over 350, 9.5.1 comp,
Axle/Gears: 3.27 aussie 9bolt
okay, i have read through all these posts, no inj. pulse, no fuel etc, now i have to pull my hair also, i have no injector squirt or pulse whatever, so i checked the fuel. its getting to and through the injector pod, the ecm is working, everythings plugged in. now its sat for 5 yrs, i just put a new fuel pump in and this is what it does to me!! aaaaaaargh! i tried disassembling the throttle body to see if the regulator diaphram was stuck, no its not, so is it possible the old gas that was in it has ''gummed'' up the injectors? can i soak them or something to clean and break that up without damaging them? can i manualy run a solvent' like carb cleaner through them somehow? the injectors and regulator all thats brandnew, and it ran great then with no probs, it sat for about 2 years and the short rubber hose that connects the pump to the sending unit fell apart but i has not ran for 5 yrs . any help would be greatly appreciated ................................................................................. thanx 92orangestripes
Old Jun 20, 2010 | 07:34 PM
shermanwizard's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: no squirt at injectors
Could be the distributor module or pick-up coil or the pole piece (it has 8 points like a star press onto the internal shaft) or all 3. Sometimes the bushings in the shaft housing can become worn enough for the pole piece and the pick-up coil to hit each other and cancel the signal for the module to pulse the injectors and/or fire the main ignition coil.
Old Jul 8, 2010 | 10:29 AM
SB406's Avatar
Car: 71
Engine: 406
Axle/Gears: 3.42 8.5" 10b
Check to see if you have power to the injectors. IIRC The Throttle body vehicles run 12v steady to the injectors with the key on and fire them via ground through the computer. Could be as simple as a bad connection or fuse.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
