305 tbi to 350 tbi swap?-PLEASE HELP!!!
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
okay i have a 90 camaro rs with 300,000 miles, im wanting to do an engine swap. i have a built 350 4 bolt main, medium cam, camelback heads,bored 20 over etc. im sticking with TBI but im having some trouble and a few questions. what is the difference between the 5.7 and 5.0 ESC modules? will i have to do anything to the 700r4 trans? will the PROM out of a 5.7 truck work? would a 255lph fuel pump work okay?
any help is greatly appreciated
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: 305 tbi to 350 tbi swap?-PLEASE HELP!!!
There are differences in the 305 and 350 ESC. If you search, I think there is one that is preferable over the others. You will also need a new knock sensor. Make sure to only use ones for TBI trucks or cars with 350's that are 92 or earlier. The later ones are meant for use with the internal ESC modules in a PCM and are not compatible.
The 255 may be a bit much for the stock fuel pressure regulator. Youd probably be better off with a 190, unless you plan to do a lot of mods.
Car: 1990 camaro RS
how do i burn my own? can i burn the stock prom?
