high RPM
Old Aug 8, 2010 | 01:11 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Transmission: 5 speed
high RPM
ok, so i have a stock 1990 camaro rs and my RPM going 70 are 4000... yes i typed that right... about a year ago it was at 3500-3750. why is the rpm so high? is the tach the problem or would it be a tranny or axle problem? oh, and brand new zoom clutch, so its not the clutch.
Old Aug 8, 2010 | 01:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: high RPM
Your tach is reading high.
Old Aug 8, 2010 | 04:46 AM
Camaro RS's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI
Re: high RPM
what should it be reading? and would that be the reason why it says my idle is 1250?
Old Aug 9, 2010 | 11:15 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: high RPM
My tach is way off as well. I have the opposite problem though. When I plugged in an ALDL cable with WnALDL on my laptop it showed way different readings. For instance, when my tach says 4500 / redline WinALDL showed about 2400 RPM. I have to push it way past redline past 7000 to even try to touch 4500.
Old Aug 9, 2010 | 11:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: high RPM
This is a common problem with our tachs. There is a resistor that goes bad on the driver board. Easy fix for it.
The electronics board here has a good thread on fixing them.
RBob.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
