Oxygen sensor question?
Old Aug 14, 2010 | 01:41 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
My car has the 305 tbi and it has a hesitation around 1200 rpm and so I unhooked the oxygen sensor and it runs the same with a hesitation at 1200 rpm, could this be that my oxygen sensor is bad? I let the car idle until operating temp and the check engne light never came on.
Old Aug 15, 2010 | 12:46 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: Oxygen sensor question?
I would use a data interface to diagnose the o2 sensor.
First check the IAC passages to be sure they are clean.
Verify good counts.
Check all vac hoses, intake gaskets and throttle shaft for leaks.
Old Aug 15, 2010 | 05:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
My thought is that it would seem the issue is elsewhere since unplugging the O2 made no difference.
Old Aug 15, 2010 | 07:44 PM
Engine: 5.0 TBI
Verify good counts.
you may think im silly but when I cold start my car there is susshing/loud hissing sound coming from where the throttle body is located but once it warms up the sound goes away but then theres a surging feel during light acceleration.
Old Aug 19, 2010 | 08:35 PM
Engine: 5.0 TBI
bump for quick replies
Old Aug 19, 2010 | 10:17 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
That sound (probably) comes from IA passage since IAC is controlled to open during cold idle - raising engine idle RPM. As engine warms up IAC slowly closes this passage restricting (reducing) amount of air bypassing throttle plates. On high mileage cars (and trucks) there might be carbon buildup in IAC passage ways.
Leaky TB to intake gasket - could also be the source of your hesitation.
//RF
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beast94
Aug 20, 2015 06:44 AM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
